working on the car yesterday not good!!!!!!!!!!!
cheeky cinqy
i started the car for the first time in about a month and its running great i revved it abit and then saw some black smoke from the exhaust checked things out, too much oil....
fitted the spotlights and only one wroks as a fuse is blown would this be down to a fuse as hazzards dont work also or because its had a dodgy alarm fitted by previus owner....
kept car running for a while and went up to 90c in but 5-10 mins and then after a while went up to about 110c and the fan didnt kick in is this normal im worried lol.....
HELP!!!!!!!! i still love it though :love:
check your fan can spin as it did it on mine the fan motor had seized over the winter also check the radiator switch is working properly
break up for school soon for like 8 weeks so i will fin the car then and try find a job lol
1 - Black smoke, quite normal if the car hasn't run for a while, but should clear. How much is too much oil? If it's way over filled you'll have drain some out via sump plug.
2 - Fuse blown, disconnect spotlight wiring and re-load fuse, check everything is working as before.
3 - Cooling fan not switching on...as above..action 2.
