Bamboo Panda
- Joined
- Jul 11, 2021
- Messages
- 11
- Points
- 2
Hello,
Does anyone have details for the wiring connections from the ECU to the coil packs and injectors on a 2007 (mk 3) Panda 1.2 Eleganza? (i.e. pinout)
The ECU numbers are IAW4AFS2, HW407/20BB-WHM, 51793116
Different versions on the mk3 Panda have different ECUs with different pinouts. This particular model has a 28 pin connector on the ECU (not the same as the model in the e-learning manual) The car has an ignition problem, I think the fault is in the wiring.. Obviously I have googled this to no avail.
Thank you in advance if you have the details or know where I can get them.
