Technical Where is the OBD II connector in my Marea Weekend?
TBMonsen
Hello
Where is the OBDII connector located on my 1999 Fiat Marea Weekend 2.0 20v 155hp ? They tell me it's supposed to be "close to the drivers seat"... any clues?
I have started to build a fault code reader/rs232/obd converter at work for my car... that I haven't got home yet from the dealer. Will be arriving tomorrow :)
Thanks for a great forum.
/ Tomas, Sweden
"5-Data link connector (DLC)"
I'm so sorry. I see now in the "sticky" at the top page where it (probably) is located. Is this the one I am looking for? Number 5 in the picture?
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
Thankyou!
I have ordered the components today, and will mostl certainly be able to start the buildup this weekend. Will come back to you with my findings.
Perhaps I can help you guys to avoid having to go to a garage getting diagnostics for outrageously high £30 that I have seen quoted on this site.
Cheers,
Tomas
Thankyou!
Cheers,
Tomas
most places around me want more than £30! i just got lucky the last time.
if you do get it to work can you let me know please as i would love to be able to self diagnose my car!
