General Where is the fuse box on an Idea?
solo3583
Northampton
I can find the fuse box under the bonnet, but does anyone know where the second fuse box is? The manual says it is behind a removeable panel below and to the left of the steering column, but I haven't got a removeable panel! Confusingly, the picture in the manual is for a LHD vehicle so I suspect they mean to the right of the steering column, but there's nothing there either.
My problem is the cigar lighter socket has stopped working so I suspect fuse F44 has blown.
On this car you will have to uncrew to Phillips screws from the panel before opening...
Hello
You'r car fuse box near the EOBD 2 sevice socket and fuse value 20A some models F44 some models F46 15 A
In case you have'nt found it yet, it's behind the panel under the dash on the passenger side. There are a few screws in the top (above the shelf) and underneath, then it unclips from the center console. Had the same problem.cheersnick
Thanks guys, sorted now. You were right - it's under the panel on the passenger side, which comes out if you undo two or three screws. They don't make it easy do they?
