Technical Where is the clutch fluid reservoir?
Zhu
I can see two but I'm not sure which is which. Usually it's on the passenger side yet the one on the driver's side looks right.
The clutch slave cylinder is on top of the gearbox. Reasonable access for bleeding means the battery box has to come out.
Air can be bled out to improve the clutch action. But, if air has got trapped, the source is usually the master cylinder seals so the problem returns.
