- Joined
- May 16, 2008
- Messages
- 1,119
- Points
- 199
Just watched the above - some good general points raised but the detail on the 500 regeneration was incorrect. It was stated that the car needed to be running at 3,000 rpm for 15-20 minutes and that if the car stopped in traffic, the process would have to start over.
However regeneration even in traffic is possible (just keep the engine running) and there is no need to run the engine at certain revs. This said the process is paused when totally 'lifted off' the throttle, hence for expedience personally I will run a lower gear on undulating land to avoid lift-off.
But generally there is no need to adjust driving and the filter will regenerate fine in 5th at 40/50/60mph.
Sorry if this has been raised already (I must have missed it).
