DickBarton
Got my wheel repaired and just put it back on...50 minutes later I got the second axle stand off and examined the damage.
I was using a trolley jack and the first side (passenger) jacked up no probs at all - removed the axle stand and slowly lower the car to the tyre. Went round to drivers side and put the trolley jack on and made sure the plate sections were touching the correct indent bits underneath the body. Jacked away and the car started to rise - I was only needing it to raise about 10mm so I could remove the jack...I got about 8mm and the car dropped...removed the jack and looked to see what had happened - the jack point had collapsed and folded...talk about weak! The next 50 minutes were then spent with several things wedged between jack and car body to try and spread the load so it would raise the 10mm - finally got it and removed the jack - trying to slowly lower the car...as it lowered the underside failed again...so I've now got a collapsed jack point with some exposed metal - what can I cover this with to help prevent rusting?
Just letting the rest of you know, I do think I was being cautious - making sure the trolley plate mated with the jack point properly and then slowly raising the car...but clearly it wasn't enough. If you ever need to repair a flat or replace a wheel - take it to a garage and let them deal with it as it appears that the jack points are made from warm cheese!
