doctorchris
Established member
Just renewed the front brake pads on my daughter's 1.1 Active at 41,000 miles.
The old pads are not uniformly worn. Both inner pads are only a little worn. The outer pads are worn to a greater extent but only on the driver's side is the wear at the limit where I feel replacement is required.
I don't post this as a problem. No part of the calliper is seized on either side. I suspect that it is a characteristic of a fairly simple brake calliper that is used on this model. The advantage is that the pads were the easiest I have ever had to replace and cost £19 for Mintex pads. In addition, a pleasant surprise on modern cars, the discs were nowhere near to their wear limit and perfectly serviceable for the lifetime of another set of pads.
It does show how important it is to take a look at all 4 brake pads across an axle when servicing the car.
