Right. Rings ordered but going to take a while to come .
Started to strip the head.
And at the same time stripping a spare mk1 16v head (which I had in my garage for a few months since moving house only to find the box I had it in had filled with water from a leak in the roof!)
In going to try dig out a mk2 head to look at to!
BUT... So far I still say the mk1 head is by far the best!
I've poked around the water ways with a endoscope (pics will come soon) and internally it looks identical. The only difference I can see is a small thin brace across one of the water jacket outlets (which is the same on all later 16v heads)
The valves are the same size but the reduced part of the stem on the intake valve from the non turbo is thinner. Also even tho fiat say the exhaust valves are not the same metal as the non turbo engine, to me they seem the same (same hardness and colour)
But bare in mind I'm comparing this to the valves from the very early 1.2 16v head that might of been over engineered and designed more for performance rather then economy like the later engines.
Also the castings of the older head are MUCH better then the tjet head.
The mk1 head has very smooth ports with no real markings from the castings and a good texture.
Where the port splits to both valves is very nice and even
The tjet head has a very lumpy bumpy ports with quite a bit of flashing where the casting half a have been.
The where the port splits is a bit miss shappen and not very clean.
Also the port itself is not even and very poor!
Also the exhaust ports on the mk1 head are about 1mm larger from each valve then on the tjet head. I put this down the the better surface finish more then anything
IMHO the tjet head has been made a lot cheaper then even the mk2 head which is ****e compared to the mk1 head
Tjet
Mk1
