yann
Hi everyone, my 2020 500 with vvt will need doing soon..I have done many timing belts but not on the vvt fire.
My information comes from that 'online data source' which purports to be as per manufacturer (we all know the one)
I'm not sure if it's ok to say it on here though?
anyway, it's procedure (again i'd better not list a printout) is all as per normal, but on the special precautions/removal chapter
there, it says warning-engines with vvt, mark cam, cam sprockets, cam adjusters, and related camshaft components prior to removal....
so, if the online tech data' is as manufacturer says, then there is no need to undo the cam sprocket/vvt etc.
(just thought i'd get your thoughts on this one)
cheers, Yann
cheers, Yann
