Rodent ECU™
The rodent ECU provides comfortable containment of experimental animals to facilitate repeated measurements of physiological and pharmacological parameters, NOT A RESTRAINER: rodents are pre-conditioned (trained) to accept appropriate periods of confinement in the ECU.
Conditions rodents for long experiments
Blood pressure, clearance, and metabolism studies are better and easier using the ECU.
The ECU consists of a molded Plexiglas canopy hinged to a Plexiglas base. The canopy has a tapered opaque plastic hood to protect the rodents from visual disturbances. Multiple slots and an end plate allow adjustment of the canopy length for rodent size and easy access to dorsal catheters and electrical leads. The base has a large through drilled slot for accessing ventral catheters, feces, and urine. Four comfortable slots are provided to support the feet. The ECU has been used for studies of anti-hypertensive drugs:development of hypertension as a function of age, renal and drug clearance studies, metabolism studies, and endocrinological studies. ECU units are tailored for different sizes of rodents as a function of body weight.
For the best results animal should be conditioned to appropriate periods of confinement in the Braintree Scientific ECU. This is easily achieved by introducing them to the ECU daily for increasing periods of time.
Available in the following sizes:
Model Description Price
G-05 up to 50 grams (mouse) $130.00
G-1 50-120 grams (rat) $140.00
G-2 120-250 grams (rat) $150.00
G-3 250-350 grams (rat) $160.00
G-4 350- 400 grams (rat) $170.00
G-5 400 - approx. 800 grams $210.00
