@Wiltshire Chris do you recall the torques you used? I had some troubles discerning which part is what in the Service Manual (and your fine torque list summary (thanks btw)). I ended up using these:
Track rod end to track control arm joint fixing, nut M8, 32Nm
Bolt securing front bush on track control arm to crossmember M12x1.25, 95Nm
Track control arm rear bush fixing, flanged bolt with unlosable, tapered, flat washer M10x1.25, 70Nm
Anti-roll bar to track control arm fixing, bolt with normal flange M8, 35Nm
Anti-roll bar to cross member fixing, bolt with normal flange M8, 35Nm
(I had two different bolt head sizes(?), No. 15 vs 13 socket for
14876634 (
ePER). I was going to ask if they (illogically) should have different torques because of this. I only tightened the No. 13 socket bolt to 35Nm, but tomorrow I'll tighten it to 70Nm as well.)
Feedback much appreciated!
Thanks,
tjr
