Technical Sump plug rounded
Gman88667733
When I last changed the oil, my sump plug was fine, no issues. Gone to do it this time and the 12mm Allen key is loose in the slot and it seems to be slightly rounded.
Any ideas?
Had a look online, it seems like 12V extractor pumps are quite popular nowadays. My only reservation is if it’ll extract as much oil as via the sump plug?
Buy a 13mm af studding connector nut
Tap it into sump plug , undo with spanner.
If it's too big to tap in file down the sides that you want to go in then tap it in.
Any ideas?
Find the tool you used to put it in ..
( get an undamaged 12mm hex.. or the new plug wont last long..) :eek:
Failing that use a 1/2" key.. thats 12.7 ;)
comes out easier if the oils hot straight from a run
I can just get my arm in without jacking the car. Have long arms not sure if everyone can do this.
Got hold of all 12mm Allen keys we have and all of them are loose.
Very strange. I had no issues at all undoing it a few months ago, nor did I tighten it much, just enough to be secure.
I always jack and support the car because the oil filter is impossible without the extra space.
the problem is the sump plug is rounded the quicker you can undo it after a run the better. Then jack the car afterwards
not that it will make as much difference today as its 28C here today
too late now but there is a lesson to be learnt.
Its easy to overtighten the sump plugs. I do mine to about 20nm
which is only what a tiny 8mm bolt would be.
I have no idea on how the OP rounded off his plug, I do all my own oil changes and there are times investing in quality tools is the way to go. I was lucky enough to purchase an eBay bargain, Stahlwille inhex usually a double figure sum, cost me a fiver. It’s a half inch socket with long Allen, ideal on my Coupe. Fannying about with those wee Allen keys or the likes leads to knackered plugs one way or another, I’m not having a go here I’m only pointing out what can happen.
Worth investing in tools that up for the job. Regarding the rounded sump plug many suggestions have been offered already, but I would purchase a new plug before attempting anything. Best of luck.
agreed
quality tool not only make the jobs easier and less likely to damage anything but last generally a life time.
I tend to buy one quality as needed not sets. Half of sets never get used.
Lets not be too hard the original poster might have inherited like this
cant remember the last time I used keys hex bits are far easier
