Technical Starter motor replacement x244
cyberfruits
Hi does anybody know the ignition wire size and the diameter of the connector/bolt on the starter motor of a Fiat Ducato 2.3 2006 x244?
On consulting eLearn, wire csa is quoted at 2.5 sq mm. Colour is red/black, diameter of stud / ring terminal is not specified. I would expect the stud terminal to be M5, but cannot be certain.
Need to cut the wire as it is stuck on the old starter which I will need to replace so need to get a new crimp connector ring. ta
