Technical Speedo problem Punto MK1 TD 1.7
Usernovo
Hello to all crew,first sorry for bad english since im not native.
I have some problem for long time,on my instrument cluster all works fine,except
the speed im driving, and the miles/kilometers,and meters the.
Already change instrument cluster (have 3 of them,same model).
Already check the plug with 3 wires,is good and conected.
Already change the speedo sensor in gearbox i leave the image attached.
Checked the fusibles seems all is ok.
What shall i check more? any relay?
Thanks in advance.
Thanks in advance.
Hi, and welcome,:)
what age is your Punto.. ?
it may be that there are different model specifications.. over the 3 or 4 years of the 1.7..,;)
Charlie
usually its speed sensor or that sprocket below on your pic, but you have changed that and it still doesnt work, i would check sensor wiring
hello,i change the sensor plus sprocket.
The sensor wiring seems ok and the plug i think its correctly conected,it have 3 wires.
The sprocket have any special way to fit on gear?is required to dismantle the gear?maybee inside gear exist some other plastic piece?
thank you
