General Speedo Cable
Been reliably informed that Floyd needs this changing & have got a replacement. Can anyone give me guidance as to where it goes? :p I'm a bit lost til I get a Haynes manual & dont want to break anything! ;)
you may need some thing that looks like this
poundland ones will be ok :)
just be careful you dont pull any wires off behind the dash, or disturb any under the bonnet. When I did my clutch cable all my hedgehogs went to sleep and stopped my electrics working because I disturbed them... (hedgehogs being little electrical connector blocks btw)!
Make sure you follow the exact route or you could up with a failing speedo cable, it took me three goes to get it right and a replacement to replace the replacement. So follow the exact route no extra or spare length on the cables. even if you fit it wrong it will work for a bit then stop reading what a pain it was to sort out. Best of luck job is easy just take your time(y)
Hey! has anyone seen my spare Speedo cable? It was in the garage next to all the Pink things.....:bang:
