Old Panda:
Depending on model you can have 10cm in the front doors, 10cm in the rear side panels, or 10cm in plastic pods on the dash. Standard wiring only provides for 2 speakers, although i guess you could put some 6x9s in the parcel shelf if you really wanted to...
Hi i bought the 13cm speakers for the back and they are miles off fitting!! i think its the 10cm you need
It's a bit late in the day for this, as I'm having the head unit fitted tomoro, but I need some info on the speakers. Are there any that will fit in the front door cards of the Panda? My friend has some very shallow Panasonic speakers in his 2CV doors but these are out of production now. Can anyone suggest a make / model of speaker that may do the job? Either that, or other mounting positions? (head unit is 4x50watts) Thanks![]()
CINQ
With a cinq you get 2 10cm speakers behind grilles under the wing mirror adjusters at the ends of the dash. You dont get rear speakers and there is no wiring for them installed. You can fit speakers in custom rear door cards very easily. 6x9's are a good fit if your wondering.
In the boot you can easily fit 2 12" subs in the standard sub enclosures, but will struggle to find room for more than 1 amp as well. 1 12" sub is recommended.
