Not knowing your 'skill set' it is a lot harder than changing a wheel on a standard 500.
Airbox has to come off. 3 nuts. Before you lift the airbox box you have to 'open' the clips that attach it to the 'tubing'.
Getting the rail for the spark plugs off is a little tricky. Before working left to right remove the 10mm nut wire attachment (like an earth wire).
You need an extension price with a plug removal 'socket' and loosen anti-clockwise and remove.
Fit new plug and continue removing old and new.
Then reverse 'operation'.
Make sure you use the correct NGK plug and check it's gapped correctly with a feeler gauge. Some individuals use copper grease whilst others say you shouldn't because you could overtighten.
If you use an iridium plug this is pre-gapped. If you wish to change the gap it is not changed in the normal way because of the delicate tip.
Make sure nothing drops into the spark plug holes !
Good website with NGK giving the correct plug and the gap.
I have to buy a new 25cm extension piece (diameter 23mm) and a new 16mm spark plug socket with a 'rubber grab bit' that was not perished so that the plug came out. Plugs are a long way down in the engine.
