Spark plug cable+ cap resistance values 1.6 16v100
vijaycool
I own a Fiat palio a.k.a stilo. The car has vibrations at idle. I do not know the history of timing belt change. It could also be a bad timing. I pulled out the spark plug cap and the wire to check the resistance. The values as follows
1 cylinder - 34 Mega ohms
2 cylinder - open circuit
3 cylinder - 18 kilo ohm
4 cylinder - 22 kilo ohm
What is the cable+cap resistance for the 1.6 engine. Does the bad wire cause vibrations only in the idle and smoothen while accelerating.
Regards,
VJ
Thanks Peter for the link.
For Fiat Palio 1.6 i can see 40424 for 8mm cable. Does this mean resistance in ohms?
OP, the resistance of HT leads will be X ohms per cm of lead.
Your longest lead would, I assume be for #4 and the shortest lead for #1 with #2 & #3 often being the same length.
If, for example, lead 1 is 30cm and lead 4 is 45cm then the resistance value of lead 4 should be 50% more than lead 1.
As your resistance values are all over the place I think it would be best if you simply bought a new set of leads.
BTW, the number 40424 is their reference number, it means...
4 = cylinders
0 = 8mm lead
424 unique reference number (for the toyota RAV4, the palio is 425)
as 47425 is 7mm and 45425 is 8.5mm
Thanks. Got it. I will go for new cable + NGK spark plug.
But one question if the cable values are all around wonder why the engine is not missing beat at higher rpm. I do get cyclic vibrations for every 2 secs at idle. Earlier it idles around 800ish but currently its ticking over around 650 rpm.
According to the NGK site 1.6 uses BKR5E . There is one more type plug G power BKR5EGP. Anyone used this G power and how good it is for 1.6 engine.
