Technical Singular beep noise, but no warning light?
princessangel
Cork
Hi there! Today my 2015, Fiat 500 started to make a singular beep noise while driving, with no warning light coming up to accompany it. For context, this is the same kind of beep she makes if the fuel tank is very low (I had half a tank of gas so it definitely wasn't that), but not the same one as a seatbelt or handbrake issue. Both times no warning light or warning message has come up. So far it has happened twice today (once per drive), within the first few minutes of driving. Unfortunately I don't know much about cars, and I'm a bit worried about her, but I'm hoping that since no warning lights are coming up (and she seems to be running just fine) that this isn't a big issue? Has anyone else experienced this or does anyone know what this could be? Thank you so much ☺️💕
Model
500 Lounge
Year
2015
Mileage
55000
Which angine do you have 0.9 or 1.2 it might have a bearing. Do you have reversing sensors?
You could do with seeing a mes user who can check all the warning lights.
For safety, check the brake fluid level and coolant level. The only spurious warnings I have had were from a failed brake fluid level sensor which had to be changed. 0.9 engines have more sensors to mislead. This could be assilly as abulb with a poor contact.
My 2013 has a speed alarm settable via the binnacle menu buttons which emits a single beep as you pass the pre-set figure. I have it set for 50kph, the 'backstreets' speed limit around here. However it's accompanied by a message in the central display for several seconds; "Exceeded Speed Limit" or somesuch. 🙃
Did think it was likely there was a message as well!- but was waiting for the OP to comment to see if we was heading in the right direction!
