Hey guys, got a question as im in a dead end and cant figure out whats wrong. My 2008 fiat 500 with selespeed cfc383 gearbox had issues so i decided to rebuild the robot. In the rebuild kit there were seals for selespeed oil pump. After disassembling & reassembling the pump to change the seals, and installing the robot on the car, the pump was not working at all. I removed the pump and now i see that it wont turn. The pump motor is working normally when i put it directly on battery without the pump gears installed. The problem is in the pump gears, when the screws are not tight at alla i can freely move the shaft, as soon as i tighten the screws, even by hand, the pump gears shaft stops moving. Any selespeed guru that can help? Or someone that maybe had a similar issue? Thanks in advance!
- Model
- Fiat 500 1.2 petrol
- Year
- 2008
- Mileage
- 148000
