Twin Air - Wiring diagram- Hi guys I have issue with reg plate lights not working, its where the wiring goes from body to hatchback - I need wire colour code for this and the back side light. Thank you
The loom going from body to hatch contains fragile and brittle wires. The problem may be there. I’ve done a couple on 2 500 cars. They are colour coded and repair looms are available that use silicone covered wires which are much better being more flexible and stronger. I’ve done loads on Alfa Giulietta cars for family and friends; they’re not so easy as all the wires are black!
The side light will be a separate issue more than likely.
