Technical Random cut- out this morning
West Midlands
Driving to work this morning my car ( fiat punto mk2b ) randomly cut out while waiting in traffic , this has happened once or twice before but is very rare. what could this be ?
EDIT:while im here , save doing two threads , my locking fuel cap doesnt want to stay on any more im thinking of replacing it , ive seen a couple of ebay , is this the best place to purchase one ?
You can get genuine Fiat locking caps with 2 keys
They aint expensive, due to panda's not coming with them... Stupid i know
Eitherway - Get one - you get 2 keys - keep the key in the car so you never forget it in the floors Vin cover (easy and hidden)
Regarding a random cut out
Loose battery terminals?
Starting signs of a failing crank sensor?
Wasnt riding clutch by accident?
Ziggy
Ziggy
Where do you recommend getting a genuine one from , Fiat ?
Also forgot to mention in original post -car is a dualogic (y)
For the cutting out, possibly TDC sensor. If it cuts out for any length of time, check for spark at plug, wet plugs (when cranked).
Code read may reveal something, but TDC seldom results in a code.
cheers , will connect it to the laptop tomorrow .
Fuel locking cap?
try here, http://www.micksgarage.com/
13quid ish,
becareful with ebay, they might send you some aftermarket TaT that will be ill fitting,
cheers for quick reply
looked on the website but got this error
Apologies!
We don't seem to have Fuel Caps available for your Fiat Punto.
Please choose another category below.
Your Car
Fiat PUNTO 1.2 60 (188.030, .050, .130, .150, .230, .250)
To:present
Engine:1242cc 60hp.
Apologies!
Your Car
To:present
Engine:1242cc 60hp.
Might be best to email ,
not all suppliers will do afull internet list on there parts,
What is the TDC sensor? My Punto seems to cut out randomly every now and then, but it usually just starts straight back up again after a minute. No indication on the diagnostic as to why though?
TDC sensor = crank sensor (sometimes called "rev sensor"). On the FIRE engines it sits at about 3 o clock to the alternator pulley on the crankshaft.
It's the sensor which tells the ECU that the engine is running and how fast it is running. Without a signal from the TDC sensor the ECU thinks that the engine isn't running, so it cuts spark, cuts the injectors. The ECU won't generally record anything as it believes the engine isn't running, and, if the engine isn't running, it believes that there can't be a fault. Sure fire test, if it conks out for any period of time is check for spark, check for wet petrol smelly plugs. If no spark and no smelly of petrol, TDC sensor is the likely culprit.
A trick which sometimes works is to get someone to waggle the TDC sensor wire while you crank the engine. If it suddenly bursts into life, well...........
thanks man, thats very encouraging :/ lol. have you had this problem im having before?
