QuoreSportivo
I have several problems with my Fiat Qubo 1.3 Multijet 2012. I have owned the car for 1 year. I bought it with a relatively low mileage (142,000 kilometers). I don't know if the mileage is real. Immediately after buying it, I replaced the timing belts (they were skipped by one tooth) and changed the oil. Then I replaced all the washers under the injectors because diesel was leaking from under the injectors on two cylinders and the engine was running too rough and had high corrections. Then I flushed the engine with BG EPR because the new oil was immediately black. And new oil went into the engine again. The engine's performance improved but the injectors still had a bad sound even though the corrections on the injectors were better. I bought all 4 new ones and we also sealed all the leaks on the injectors. I had the original engine control unit software uploaded because we found that it was modified in various ways. So I currently have the distribution replaced, the engine flushed, new oil now with about 2000km of mileage, all 4 new injectors and no diesel leaks, EGR turned off, DPF active (regenerations work).
However, after starting the engine, I can still hear a relatively rough sound until the engine warms up. We looked at the injector corrections today. On cylinder number 1, the corrections were about 0.70, on cylinder number 2 0.40, on cylinder number 3 1.20, on cylinder number 4 0.04. Gradually, as the engine warms up, especially on cylinder number 3, the corrections noticeably improve to somewhere around 0.70 and the engine still hasn't warmed up to full temperature. When the engine is warmed up to operating temperature, it runs clean and quiet. What could be causing this?
The second problem is the DPF regeneration process itself. Regeneration is quite frequent and always accompanied by a lot of smoke from the exhaust. The smoke is slightly blue. It doesn't smell like coolant, I'm not losing it. It doesn't smell like diesel either. It's more like it's burning a certain amount of oil. I'm not losing oil, but I suspect that my oil volume is increasing. Which is also not right. Have you ever encountered an increase in the amount of oil, or such strong smoke during DPF regeneration?
The new oil applied after flushing the engine was immediately completely black again and it also seems to me that there was quite a lot of pressure coming from the PCV hose connected to the airbox after disconnecting it. I want to find another car with a 1.3 Multijet to find out how strong the pressure is from the PCV hose.
I plan to flush the engine again with BG EPR, then use new oil (some cheap 10w40) and then, after driving some distance, drain the oil again and pour back in Selenia 5W30.
I am attaching a photo of the smoke from the exhaust during DPF regeneration and the color of the oil after flushing the engine and driving about 20km.
I will be grateful for all advice and any help.
- Model
- Qubo
- Year
- 2012
- Mileage
- 147000
