Technical Punto Mk2 Whats this warning light mean?
robbenington
Hi this one is easy .... if you know it!
Can you take a look at the pics and tell me what this warning is about? (Not the handbrake one....!)
If it flashes when you start the car and goes out after a few seconds - normal
If it comes on when you turn ignition in and is lit continuously when engine is started - Means you have your passenger air bag switched off
Passenger airbag is manually disabled
This is when you have a baby seat fitted
Its to prevent the baby seats been smashed by airbags in a crash
Open the passenger door
On the dashboard thays covered up by the door is a key switch
Stick your key in and turn it
When ignition is then turned on itll flash as it arms/self checks then go out meaning its in operation
The big worry one is the red light next to it
Brilliant! problem solved.
The electronic thing was showing a false driver airbag problem lighting the red blobby airbag light which failed the MOT: now sorted by plugging it in and resetting the electrics - £24.
In cluelessly fiddling about, I turned off the passenger airbag. Turned it back on again now.
Thanks very much.
(y)
Rob
Thanks very much.
(y)
Rob
Showing a false problem
Dpwt that
Airbag systems are usually good at been near direct with faults
If it was a low voltage fault then u can sorta ignore it
But dont be surprised if the light comes back on
