Hi!
Differential gear didn't like the extra power so I decided to to find a 6 speed gearbox from Fiat Stilo 1.2. There's no 6 speed Puntos in Finland, or at least I've never seen or heard about one.
I had to change original gearbox mount and clutch slave cylinder (or I meant to..). 6 Speed gearbox is a bit longer but doesn't matter, it won't hit anything. 6 speed was a bit heavier also. I changed 16V clutch at the same time to my 1.2 8V Punto, it fits perfectly. Long 1/4" 10mm socket was everything I needed for centering.
Assembly was a bit hard to do alone but I managed to align the gearbox by hanging it with load strap to correct height and used wood blocks to get the angle correct. Then I just pushed them together.
Everything went fine until I started bleeding the clutch, brake fluid everywhere. Something broke. I needed the car next morning so I modified the Stilo slave cylinder to fit (same in newer Puntos). That was pain in the ass but I managed to modify it usable after two hours, still working great
[ame]https://youtu.be/58U2uFKhwMo[/ame]
[ame]https://youtu.be/XKhQyWgyd2s[/ame]
Next thing is, of course, change the gear knob to 6 speed. Didn't find any mk2/mk2b ones for sale so I modified it from Grande Punto. Had to drill the hole a bit larger but that was almost it, fits nicely
[ame]https://youtu.be/_bLtv8vDeWM[/ame]
