doctorchris
Established member
A little whinge, here, from me.
I like to keep spare bulbs in my car. It is impossible to be sure, on the Cross, which bulbs are fitted in the spotlight pods to provide main beam. The supplementary 4x4 handbook is no help and looking through the lamp lenses didn't help.
So I followed the handbook instructions for bulb replacement to the letter, to enable me to examine the bulbs. The plastic surround to the pods is released by undoing three screws under the bonnet. It's then held in place by 3 press-in studs, very similar to the studs that hold door cards on. These inevitably broke when pulled on. Unlike with a door card, it was impossible to get behind the pod to ease the studs out without damage. To make matters worse, the mechanism of the studs had been jammed with small bits of plastic at the factory to make them almost irremovable.
Fortunately, Halfords had some studs that fitted almost perfectly and the car is back together again.
By the way, the bulbs are H1, but I'm sure some clever so-and-so will have known that already.
The moral of this tale. Don't mess about with Panda Cross lamp units unless you really need to change a bulb. When you do need to change that bulb you will break something.
Do any of you guys out there at the dealers know if I can get hold of the proper studs? Just me being obsessional but I would like to have a few.
If anyone cannot understand my description I will try to take some photos but it's pissing down here just now.
