Hi there , after some advise please . Got a fiat ducato 3.0 litre with a engine management light on and had it checked out at a garage . The code stored is p2563 turbo position sensor . Any ideas what could be causing this fault ?
hi ya not to sure on the age of your ducato but mine is a 57 plate 160 multijet with a ford Iveco engine, I have had this problem and replaced all the sensors to no avail, it has turned out to be the throttle turbo actuator, I have been told this is a common fault on these engines but don't hold me to it, check it out, hope this helps
wtf new turbo is about £1700 plus fitting, you can get a secondhand one for about 250 on ebay or turbo rebuild people should be able to supply a sensor for 100 ask this guy for example: http://www.ebay.co.uk/itm/Electonic...arts_Vehicles_CarParts_SM&hash=item4ac4d02692
If you're asking around the turbo rebuilders the garrett number for your turbo is probably 796122-5001S or 796122-00001 they should be able to tell you which sensor you need, as carpmanic said could turnout to be the actuator.
