Technical P1220: Series throttle control malfunction
Rostov-na-Donu
The car at regular intervals became in emergency operation.There was a languid reaction to a pedal of gas. Properly to go in such mode it is impossible. There was such mistake on scanner: P1220 (SERIES THROTTLE CONTROL MALFUNCTION). I have changed a throttle body with Self-adaptation reset, Phonic wheel learn reset. Two weeks has spent properly, and then again these problems. I from Russia, cannot achieve the reason for this mistake anywhere. Prompt, please, in what maybe a problem : Rejected throttle body, ECU, wiring ? Where it is possible to find the literature on parameters, pressure, resistance of this system.
Excuse for my English, Vitaly.
What car/ engine is it?
Do you have air con?
When the ECU cant understand the feedback of "Where is the throttle valve position?" then the ECU goes into "get you home" mode with limited rpm and a P1220 fault code and sometimes P1687
You need to find out why the throttle valve feedback is bad.
Is it the 5v reference being supplied by the ecu?
Is the 5v getting to the throttle valve?
Is there a poor connection at the throttle valve?
Is something else interfering with the 5v supply eg aircon linear pressure switch, MAP sensor circuit or anything else on the 5v supply
Is the feedback from the 2 Throttle body potentiometers smooth and consistent as the throttle valve opens and closes ?
Is the feedback voltage getting back the ECU?
Is there a poor contact at ECU connector?
So, it could be ECU, the throttle valve or the wiring in between, impossible to guess
Did you mean you have changed the whole throttle body? You don't have a phonic wheel on a 1.6 so do you mean a throttle valve relearn?
I would test the Throttle body connector for poor contacts
I shall check up first three items of your recommendations.
Yes I have changed whole throttle body. FiatEcuScan, there is no function "throttle valve relearn"
photo41744172_173934626
If you changed the whole throttle body and the problem was gone for 2 weeks but then returned then I would even more check out the throttle body electrical connector for poor contact and loss of connection (electrical contunuity) between ECU and throttle body
Also I made manual procedure of hrottle valve relearn:
Turn the ignition key to ON position (engine off)
Wait 60 seconds, the time required for the control unit to check the throttle body's internal spring and the butterfly's maximum/minimum angles.
Turn the ignition key to the OFF position
Wait 10 seconds, the time required for the control unit to save the learnt values in EPROM.
My Car, Bravo 150P got the same problem recently, error code is P0121 and P1688, when the check engine light on. the car will be hard to accelerate, the engine will not go higher than 3300 RPM. where do you think i can start from to fix this issue.
got the P1220 on a 2009 KA, did anyone get to the bottom of this?
Have you found any solution to the problem?
My wife has a Ford KA MK2 (2015) 1.2 55kW and yesterday the same error P1220 popped up, it was possible to clear it via OBD but we'll see if it doesn't show up today.
The fault seems to have been fixed, I dismantled the gas pedal, cleaned the contacts and the car drives without errors.
