Hello,
I've had problems with my 500 where as I'm driving the car will suddenly start to judder and lose power. As it might if it were about to stall. I had it taken to a garage where they cleaned the carb and the problem seemed to be fixed but it has now started again. This time it only happens very occasionally and hasn't resulted in a total breakdown as it did before.
It happened once when I was driving slowly so I stopped, put the car in neutral, and tried revving the engine. What I found was that even with the accelerator peddle fully depressed the revs stayed reasonably low. After releasing and depressing the pedal again (not sure how many times I did this) the revs went back to normal.
Something is happening that is causing the revs to sometimes stay low, which causes the car to judder and stop if it happens when I'm driving. Any idea what might be causing this?
A mechanic that attended during the breakdown suspected there was an overfuelling issue (he said he smelt fuel on the spark plugs). I'm not sure if this is connected. Perhaps an issue stopping fuel going to the right place is sometimes causing the car to have issues revving as high as it should.
Any advice very appreciated.
