Tuning OBD port on a 2007 Fiat Doblo 1.4L
qaz83885
uk
hi,
anyone where the OBD port on a 2007 Fiat Doblo 1.4L can be found and a list of codes for this van
thanx
Hello,
For the port location the easiest way would be to check in the owners' manual. Check the download section of the forum if you haven't got one.
For the error list, reading the errors with MultiEcuScan will give you full description. So will do other 'quasi-professionnal' readers.
Cheap chinese interfaces can give faulty information.
OBD regulations state the port should be between the centre and drivers side of the vehicle, which gives plenty of scope. Most Fiats have them above the driver's right foot, either visible below the dash, when one's head is in the footwell, or behind a panel just above that point. Might be a coin tray or similar needs heaving out.
In the x250 Ducato it's hidden behind a cover, which needs to be unscrewed with a screwdriver... So it can be hard do find. It's easier to check in the owners' manual first.
For me, the first place to check without the manual would be by the fuses.
I have a 2010 1.3 and it is at the bottom of the fuse box. The fuse box is behind a panel to the right of the steering column and down. Pull the top and it folds down.
