+Speed++freak++
- Joined
- Sep 27, 2007
- Messages
- 109
- Points
- 34
I'm looking to get Some Nos, Without frying the engine !whats a safe amount 25hp or could I stretch to 50hp jet?
I did, they will allow it, The Different Nos jets produce different power levels. like for example A Nitrous jet size of .030" or 0.762mm should produce:What's this 50 hp jet thing?
Check with your insurance first -- they're usually pretty kind as regards Nos, pretty strict about who fits it. (For obvious reasons -- they don't want someone zooming along the road under the influence of a -- pretty powerful -- mind altering drug.)
As you won't be able to afford to run it for extended periods (and probably have some cut out to allow Nos only in higher gears) then you may be able to get away with 100% more power for short periods. The crucial thing is to have some means of increasing the fuelling when the Nos is injected, and harder plugs, otherwise you will eat a piston (or two) within a few nano seconds.![]()
stick the fogger in the bob, above the TB, i made a custom ss bob for this.
