- Joined
- Jan 3, 2014
- Messages
- 298
- Points
- 54
Will try itcheers for the help, where is this other place you can ground it to is it the boot lock or something?
Any bolt on the car will work that's through the shell if you make sure it's metal on metal, I usually found one in the compartment to the side of the boot that houses speaker wires/rear lights. Remove bolt and polish/remove paint so it's a good contact with the connector and then that should be ok. If earth was a problem it may be blowing fuses - mine did anyway but it also blew the amp up at the same time
