Hi Liam,
Welcome to the forum.
I have noticed your plight while scanning another forum of which I am not a member.
I hope that the best advice to date, turns out to be to post here.
For the benefit of other readers, your starter motor failed to work after refilling your tank. A faulty starter was diagnosed by local mechanic, and replaced. The new starter also failed to function, with a smell in the cab.
The other advice that you have received, while well intentioned was either incorrect, or not applicable to your vehicle.
Perhaps ypu could state why you think that the wrong starter was fitted? There is at least one other possible cause for your problem.
If you input your Vehicle Identification Number (VIN) into electronic Parts Equipment Register (
ePER) at the top of the page you should be able to extract the starter part number for your vehicle. However while others have succeded, I have not needed to use
ePER myself.
Please note that it is quite possible that the original part number has been superceded.
The VIN number will be on the VIN plate, which is normally located on the cross member over the radiator. I expect it to have the the form ZFA244..........
I am sorry that I cannot help with details of a garage in Paris.
