Hello, if you have a 2007-2015 Lounge, Sport or Abarth model no doubt you will have a Fiat ‘blue and me ‘ l
handsfree module fitted in the rear passenger side panel (For a UK
car)
When this fails it can cause a permanent 24 hour battery drain even when the car is turned off and locked……
The only solution is to access the module and physically unplug it.
This will immediately stop the parasitic battery drain, but, if not already, will cause the mileage to flash.
This is because the car is ‘looking’ for the now missing module on the canbus data network.
It shows its unhappiness by flashing the mileage !
Blue and Me modules can be repaired and refurbished- example here :
If the module is refurbished and refitted your mileage will stop flashing and the handsfree function will work again.
Alternatively, I would recommend leaving the module permanently unplugged, have a procedure called a ‘proxi alignment’ carried out using Fiat compatible diagnostic software, such as
MultiECUscan.
This will stop the mileage flashing as the car re learns no longer keep looking for the now unplugged blue and me module.
Personally I would recommend considering a stereo upgrade to an Xtrons touchscreen wireless Apple CarPlay/ Android Auto touchscreen unit.
Examples on Amazon UK:-
They totally transform the car and work with the Fiat atrrrjbg audio buttons as well
