Network issue!
Network issue!
100% and issue with Windows 7. Never seen anything like it.
Also to do an nslookup. GO to start -> run -> cmd
then type nslookup
then at the prompt type > google.co.uk (then press enter)
It should return a result like the one attached. (Oh lookie my ISP support IPV6 :slayer:)
Did you run this from the command prompt (in an elevated cmd window):-
netsh int ip reset c:\resetlog.txt
followed by:
netsh winsock reset c:\winsock.txt
Then:-
arp -d
If you can ping 192.168.1.254 and get a response then it must be an issue in the fact Windows 7 isn't using it as a Default GW (even in though in the config it is) OR your router / homehub POS is discarding the traffic....
then type nslookup
Chris, will do that tomorrow and let you know the response.
followed by:
Then:-
arp -d
Yeah I did the exact same as the above mate. As above, will do the nslookup and let you know. I think all the crucial steps have been taken though, nevertheless, its worth a try.
You had McAfee all this time, even a dumbass like me knows you delete that as soon as you find it lol. I am currently using Microsoft Security Essentials and have not had a single issue, tried others and they just suck the life out of my PC and as I am windows based on everything, it just seems to work fine
