General my 1.3 multijet starts and the dies after 3 seconds please help
ravi3729
Guys , please help , my fiat palio 1.3 multijet starts at once in the morning but dies soon after it starts ,I have give it some petrol smell in the air intake hose pipe to get it start after starting it starts and runs fine for the whole day. I've spend a huge amount of indicators and pump but the are unable to solve this problem..it all started after I have added 40ml diesel additive in my fuel tank from that day it is hard to start guys please help .
Hi,:)
look / SEARCH in the panda section..,
LOTS of MJ info . solutions in there, (y)
my suspicion would be low rail pressure ( failing HP pump)
as once it's running , the rotating speed of the pump increases.;)
do you have any pressure figures..??:confused:
Bro got it checked and found OK.the air filter is broken ,could it be a faulty maf sensor or an egr issue , turbo is repaired so he must have cleaned the egr valve
Hi,:)
Bro it is showing these error codes if u can help I don't want to spend a lot. Please reply
