Could someone please give me some guidance on this one, I have replaced the cylinder head gasket on this 1.6, 16 valve fiat engine and now struggling with a low compression issue where the engine refuses to start.
The engine was running but had an internal coolant leakage on cylinder 1, therefore having replaced the head gasket.
Now after having purchased the timing tool kit, I set the cam timing as it should be, but still not able to start.
With a compression tester, it shows low compression on cylinders 1,2 and 3.
The valves are NOT bent, postons and rings are good.
It sounds like incorrect timing, however. I did set the timing with a timing kit on the cams, so I'm at a loss for words on this one.
Am I missing something or perhaps doing something wrong?
- Model
- Fiat Siena, 1.6 (16 Valve Engine)
- Year
- 2002
- Mileage
- 180000
