natsul73
Hello,
I'm wondering if anyone can help? We're very desperate now :-(
My mum was widowed in 2019 and had always gone away caravanning with dad for most of their 40 years married life together. In 2020 she decided to purchase a 2005 Fiat Ducato Autotrail from Maquis, as she missed those days and felt ready to give it a go on her own. They didn't have anything in her budget range, except for this one, which was shipped in from elsewhere (god knows where??) She fell in love with it instantly and bought it there on the spot!
Ever since she's had nothing but (severe) trouble with it. The immobiliser light would come on whilst driving and simply turn the whole thing off - engine - everything! Very scary indeed.
The first time it happened in 2021, after much investigation to the fuel side of things (the engine would turn over sporadically, but no fuel would get to the engine) it was eventually pinned down to the ECU failing after 2 months sat in Fiat and going back and forth with Cartech towards the end in Cornwall. They sent back 2 x refurbished Bosch ECU's (ECU 1 + 2 they called them) plus the original. But, Fiat totally ignored their instructions (they said to try the cloned EC1 first and then ECU2 if that didn't work) but ended up putting the original back in too and said that it was working again. Fiat totally ignored their instructions and just put the original back in as they had got fed up of the job and wanted to send it back home to us! ECU 2 had to be sent back to Cartech as it wasn't paid for and was a favour from them, and we ended up with ECU1 as a spare.
Anyway, after 6 months use, it happened again in 2022! This time it went to another garage for a further 2 months. Exact same issues. Exact same outcome. They tried the cloned ECU 1 as well as tinkering with the original and only the original seemed to work eventually again (again, after a lot of work being done on the fuel pump, injectors etc etc).
She managed to get 1000 miles out of it this past year and ONCE AGAIN - it failed to start again on site on her first trip out in May this year! Immobiliser light back on, no start. The original ECU has been checked by a different company and they said it's dud - only works sporadically, especially when it gets warm/hot. ECU1 clone was also sent to this company, they de-immobilised it last week and nothing. No fault codes, no immobiliser light, nothing. It's just dead and fails to communicate.
When the garage manages to get the original to work temporarily again, it talks to everything ok, but it's not creating enough pressure before the injectors fire. They said they've also replaced the DRV valve? Ad when it's disconnected from the regulator, there's too much rail pressure! (I have no idea what any of this means, so I'm hoping I'm explaining it correctly?)
We're feeling like that's it. There's nothing that can be done with it. It has to be scrapped, as no one can help :-( But the van is lovely, immaculate and has very low milage and worth over £20k - it seems crazy to have to do that??! But we really don't know where to turn with it next.
It seems the Bosch ECU is very hard to find and when I looked up the part number, all the issues we're experiencing are listed as known faults on their site, they're exactly the same!
Has anyone else experienced this same issue at all? And if so, did you manage to find a solution??
To date, we've used Cartech in Cornwall, Pelican Diagnostics and AC Tronics now for the ECU work and all say the original has full comms, but only works sporadically and is affected by heat. ECU 1 reports are very sketchy and dont correspond with each other at all (AC Tronics said there was no data on it, yet Cartech said they cloned it over perfectly. Pelican said last week that he had full comms with it and was working fine. Arrrggghhh!)
I really hope someone can shed some light on this and can help my poor mum in some way. It's making her very ill (she shouldn't have to be dealing with ongoing stress this at the age of 74!)
Thank you in advance, her daughter, Natalie
- Model
- Fiat Ducato Autotrail
- Year
- 2005
- Mileage
- 37000
