Thanks for the very prompt reply. I will have a chat with my mechanic to see if the brake issue can be addressed and that it will fit. Have you any idea as to how much you would want for it to include a courier to s.Wales - as I have no transport until the repair is completed. Any chance of a picture to show condition? Cheers, SteveKI have a complete one from a 2001 1.9 JTD, It has drum brakes but I believe its possible to retro fit the later model discs, it needs new radius arm bearings but should be an easy swap whilst off the vehicle, its not rusty though.
Located near Skipton in North Yorkshire
TheThanks for the very prompt reply. I will have a chat with my mechanic to see if the brake issue can be addressed and that it will fit. Have you any idea as to how much you would want for it to include a courier to s.Wales - as I have no transport until the repair is completed. Any chance of a picture to show condition? Cheers, SteveK
The brake issue is a non issue your mechanic can keep all the bits (apart from rusty axle/sub frame/bridge )from your car and fit them to the non rusty axle/subframe/bridge .Thanks for the very prompt reply. I will have a chat with my mechanic to see if the brake issue can be addressed and that it will fit. Have you any idea as to how much you would want for it to include a courier to s.Wales - as I have no transport until the repair is completed. Any chance of a picture to show condition? Cheers, SteveK
Thanks a lot Jack, I will contact mechanic tomorrow. Any chance of a photo or two to 07871828842? or [email protected]The
The only difference between radius arms is ; you cant fit non abs radius arms to abs vehicles ,unless you drill the arm to accept the abs sensor .
Best wishes
Jack
Hi,Thanks a lot Jack, I will contact mechanic tomorrow. Any chance of a photo or two to 07871828842? or [email protected]
HiThanks a lot Jack, I will contact mechanic tomorrow. Any chance of a photo or two to 07871828842? or [email protected]
It seems yours will fit Jack, any chance of photos, and if OK will arrange a courier. Cheers SteveI have a complete one from a 2001 1.9 JTD, It has drum brakes but I believe its possible to retro fit the later model discs, it needs new radius arm bearings but should be an easy swap whilst off the vehicle, its not rusty though.
Our
Hi
The axle is from a vehicle with abs brakes, I will try and get a picture this weekend for you.
Its a very heavy item so maybe it might be better to remove the radius arms if you don't want them to save transport costs.
I have no use for it as we swapped the whole lot over when the radius arm bearings needed changing so £20 for packaging it up if you want to arrange a courier as I don't really have time.
I'll give you the post code if you want to sort a courier.
@LongprestIt seems yours will fit Jack, any chance of photos, and if OK will arrange a courier. Cheers Steve
Yes I believe you are right.
Hi, Have had a look thanks. How much would you want before I contact Shiply please? Cheers, SteveFew pictures for you. Its in pretty rust free condition but was removed from car at least seven years ago and dry stored. Radius arm bearings need replacing but easy job off car.
You could try 'Shiply' to get it picked up.
Hi Steve, how about £45?Hi, Have had a look thanks. How much would you want before I contact Shiply please? Cheers, Steve
Hi,Well from direct contact with balldee1 via the email address they added they have informed me that not interested in my subframe as sourced one locally!
Pointed out it might have been polite to let myself and everyone else on here who helped them out know and thank us... way of the world these days - puts me off bothering to try and help out.![]()
Hi, had this myself theirs a gentleman does multipla spairs and had a few I know this post was Jan so possibly sorted by now. I replaced all the back bearings and that worked for me but it was euro parts quite expensive.maybe yours is not that issues? In any case hope its sorted! Only seen one ugly bugs on the road in almost a yearWhere Oh Where, is it possible to source a rear axle for a 2008 Multipla 1.9 Multijet in the UK or elsewhere.
