Multimedia Android Center Console Unit Change - Requesting Advise
Angelos Finos
Hi guyz,
I own a GP t-Jet 1.4 of 2009, and has Blue & Me multimedia console installed.
Since I experience some issues, which are mentioned bellow, I am thinking to replace the stock B&M unit with an aftermarket one. However I 'd like to keep the steering wheel buttons and specifically the volume up/down, track change next/previous, the mute and the answer buttons. I have read some stuff about buying adaptors like the Connects2 etc, and then I saw these two units:
https://www.aliexpress.com/item/4000306433215.html?spm=2114.12057483.0.0.58fa7d04211otB
https://www.aliexpress.com/item/329...earchweb0_0,searchweb201602_,searchweb201603_
So I have some questions:
- Has anyone from the forum bought/installed or has any experience from a friend for any of these? Are these plug n play?
- I see these units have built in Mic in the front of their panel, so there is no need to somehow connect the car's built in one, right?
- Do I need to remove/disconnect the B&M console inside glovebox so no connection disruptions occur from 2 Bluetooth devices inside the car?
- These units comes with some connectors inside the packets as I read, but would you recommend buying also the Connects2 adaptor just to make sure that steering wheel controls remain working?
Would greatly appreciated your help guyz on this.
Problems I currently face: auto connection is no longer happening since I have to manually connect my phone through the phone settings. After some minutes of telecom through B&M a strong irritating sound comes up and continues on even if car is turned off rendering the console unusable for over an hour usually or until disconnecting the battery (radio, music from USB and etc works just fine yet)
