Richard W S
Hello
Just wanted to pass on my experience of using an Elm 327, bought from ebay (https://www.ebay.co.uk/itm/133786524576) and the Multiecuscan software to perform a Proxi Alignment on my 2016 Fiat Ducato based motorhome following a replacement airbag ECU.
I followed the excellent guides from @theoneandonly to backup (https://www.fiatforum.com/guides/backup-proxi-file-on-mes.875/) and then proxi align (https://www.fiatforum.com/guides/new-proxi-alignment-with-multiecuscan.890/) the ECU.
The process was very simple, once I had setup the lead properly with my laptop and Multiecuscan, although I did get an error as I have replaced my head unit, similar to one @jnmmoore (https://www.fiatforum.com/threads/proxy-alignment-help.507668/) had earlier this year.
So I headed up to my loft to retrieve the original head unit, pulled out my replacement, rewired in the old unit and set off to connect and proxi align it again, to my surprise it had completed the PA, telling me that one wasn't required, so although it throws the error if you've replaced your head unit it does align the airbag. Wasted me an hour or so, hopefully it will save someone else the time! and hope @jnmmoore's MH is back in service!
Any thing else I can do with Multiecuscan to make the vehicle better?
Thanks for the help and guides, really appreciate the effort of people to post their experiences.
Cheers all.
Cheers all.
