- Joined
- Mar 13, 2011
- Messages
- 7,620
- Points
- 1,453
Item 3: View to the Front
To clear up some confusion when considering ‘view to the front’, from receipt of this special notice you should consider the following before failing for damage or obstruction within the swept area of the windscreen.
From the driver’s seat, check the view of the road through the swept area of the windscreen. Only fail the vehicle if there is damage or an obstruction -
in zone A, greater than a 10mm diameter circle and which materially affects the driver’s view of the road.
in the remainder of the swept area, greater than a 40mm diameter circle and which materially affects the driver’s view of the road.
Note: Where any damage or obstruction does not impair the driver’s view of the road, the vehicle should pass. If it only affects the driver’s view of the sky or the bonnet then this is not to be considered a reason for rejection. This is a general assessment of driver’s view – you are not required to speculate on the effects on tall or short drivers. Any manufacturer’s original design characteristics are to be accepted.
The inspection manual will be amended at the next available opportunity.
