Technical Manky B-pillar renewal
d0mokun
West Midlands, UK
Hi everyone,
Apologies if this is an obvious one but I have done some serious Googling and scoured many a forum, only to find brief mentions but no real advice.
Our A500 has some really manky peeling B-pillar trims and I want to reskin them. Question is, do they just pop off or is there a more technical way of removing them?
Dan.
They are held on by two torx screws. You have to move the door rubbers out of the way to get to them. Fiddly but once the two screws are out the just pull off. Fiddly to get back in too.
Brilliant, perfect- thank you. I'd have likely missed things under the rubber and hulked the buggers out.
Dan.
Yes, I nearly did that once. It was only when I was taking the smashed up door apart for parts that I took the door rubbers completely out and saw the screws. Make sure you don't drop them into the window cavity in the door. They are a bugger to get out if you do. I now stick a length of masking tape across the aperture in case they drop.
Ah OK, thanks for the tip. I have to take the door card off also to tighten a rattly regulator. I really love the Abarth but the hard suspension definitely takes its toll on parts.
With regard to the seals, am I looking at the right areas (as per the photos I've attached)? Is there a magic to getting them off other than just prying them free?
Thanks a million.
This one is a 59 plate, so just touching 10 years old now.
I have a sneaking suspicion someone previously used something like an alloy wheel cleaner on them, or at least something a little more hardcore than soap and water.
I've certainly read online about the finish peeling on the trims but never beginning to corrode, though I guess if they are left for long enough that'll happen!
Dan.
Now the next golden question.. with the window down and the trim removed, I can't raise the window can I?
Edit- panic over. The window just slipped on the regulator guide or whatever it is. I removed the inner card and put it back on, now it raises perfectly even without the trim on the outside.
I've taken this moment to tighten the rattly regulator bolt and fit some sound matting!
