Technical Low turbo boost/ Manifold Absolute Pressure/Barometric Pressure Circuit High Input"
JOJOLYLE
FLORIDA
p0299 p1220
Please help me locate the map sensor if you think this is the first place to start. I have spent several trips to the lot and still cant find it. It goes into limp[ mode when the pedal is pressed on in higher gears. No smoke, or noise
Model
Promaster
Year
2014
Mileage
149000
Details of a typical manifold pressure/temperature sensor are attached. I understand that they can suffer from deposit fouling. You have not supplied engine details, but these sensors are mounted on the inlet manifold.
  • Bosch Absolute Pressure Sensor.pdf
