Technical  Loosing coolant.
North East
Im having to top the coolant up every 2/3 days as its bone dry after this time period, however I have looked for a leak in hoses and radiator and everywhere else possible for a leak to come from but found nothing, theirs no pooling under the car and im not noticing any water being burned off in the exhaust plus the oil shows no sign of a water ingress. Could I be loosing the coolant in any other way.
Loosing coolant is bad just on its own, might be worth pulling lower timing belt cover off to inspect the water pump(if you havent done so already).
See if coolant leaks there, also the "mayo" in oil never always happens when the HG blows as my old engine before the swap, never had mayo but hg did blow and did have signs of coolant mixing with oil in exhaust.
Check every single hose carefully for any signs of slits, holes etc check their clips to see they are fastened down, you must find where the coolant is going otherwise you'll toast your engine sooner or later which means either engine swap or new car.
Benny
Easy answer - Yes! It must be going somewhere.
Firstly, until the leak is fixed, check the level more regularly and top up long before it disappears from the header tank. Also find the bleed screws and make sure it is bled. This will ensure that although the level is low, it will still do its job, otherwise more damage will occur.
Possibilities:
1. External leak. You've checked all these, so we'll assume you've not missed anything.
2. Water pump. These tend to leak only when running, and often not until the engine gets hot and the system pressurises. The hot coolant will evaporate from the pump leak, so this is difficult to spot. Remove the cambelt covers and (with the engine stopped) feel around the pump for any signs of dampness or crusty deposits indicative of a leak. You may wish to run the engine for a few minutes, then turn off and check again. Careful, it will be hot.
3. Heater matrix. Do you get a sickly coolant smell inside the car? Otherwise difficult to diagnose until it makes the carpet wet. Like the water pump, this will mostly leak when hot and evaporate. Run the heater on warm and to the screen and see if it puts deposits on the screen. Otherwise may need a system pressure test to find it here.
4. Head gasket. Usually this will pressurise the system, so bubbles will appear in the header tank while running. Run the engine from cold and observe the header tank, see if it bubbles or over pressurises. This will also show if the pressure cap is not holding the pressure. Sometimes the head gasket will just take coolant into the cylinders and not pressurise the system. Spark plugs may show signs of rust! Again a professional pressure test may be necessary.
Hopefully this will help and others may add to/amend this list.
Compression test. If it's running dry (or if you're allowing it to run dry) chances are the HG is goosed.
But refill, bleed, run the up top temperature and with the car running, crawl underneath, likeliest places for "invisible" leaks are water rail, water rail o ring, water pump.
I've yet to see mayo in the oil of a FIRE engine with a blown HG and have seen mayo in engines that were just used for short trips.
