I can’t really confirm that, sorry. But in theory this looks right. That switch puts power for the parking lamps and headlamps and then the stalk switch decides between the two.Can you confirm if this is correct as per the wiring dia
I've got black as the feed
Dang it. I had hoped that the bulb swap might help.Been on it again today, getting nowhere packing up.
Gonna remove all wires to fuse box and continuity check every wire from each light as it seems like one must be crossed.
Can anyone please confirm if main beam lights the upper or lower part of the headlamp as its hard to distinguish head from main beam, want to have them correct.
Sorry, I replaced my headlight wiring harness with a LED setup, so I cant help.There's something funny because sides and heads seem to affect each other re brightness so I'm gonna take the lights off and record all the colour wires at each connection and test them back to fusebox.
Any idea on the headlight/main beam upper lower config?
Mine is lower half of light for main, upper for head.
