ClockworkOrange
- Joined
- Feb 23, 2013
- Messages
- 35
- Points
- 12
I actually want to get my car up and running as quick as possible so I think I will put the idea of a 1.4 conversion on hold for now and put a 1.2 in and see how that goes as I want the easiest option to get the car up and running again after this head gasket failure.
I have read the guides on fitting the 1.2 and it is not clear what donor engines are suitable for the basic 1.2 8v transplant. Is only the Mk1 Punto 8v engine suitable, or is the MK2 Punto 8V also OK for this transplant?
I have seen this MK2 Punto 1.2 8v engine on ebay which seems relatively low mileage http://www.ebay.co.uk/itm/150925523787
Would this one fit in without needing to mess about changing the ECU, wiring loom etc, i.e a straight swap?
Do I need to get a Supersprint manifold for the 1.2 8v conversion or does the std manifold fit OK?
Finally would someone who knows what they are doing be able to supply the exhaust extension piece required to get the exhaust to fit for the 1.2 conversion? I would very happily pay for it.
