- Joined
- Aug 13, 2006
- Messages
- 3,246
- Points
- 606
When you have an intermittent lambda sensor fault, check more obvious things before forking out for a new sensor. It cost me £70, 2 hours and a possible permanent scar to my wrist to work this one out. In the end, all it was was a dirty contact between the ECU and wiring loom, solved in 5 minutes.
How I did it:
1) Read fault using MultiECUScan.
2) Replaced lambda sensor at cost of £70 and 2 hours of my time.
3) Fault still there, so sprayed contact cleaner on lambda sensor to wiring loom connector.
4) Fault still there, so sprayed contact cleaner on both ECU to wiring loom plugs.
5) Problem solved.
How I should have done it:
2) Measured resistance from sensor wiring
3) Confirmed sensor OK, sprayed contact cleaner on all relevant connectors at a cost of only £4 and 5 minutes of time.
4) Problem solved.
So I'm left with a used, but fully functioning post-cat (Bank 1, Sensor 2) lambda sensor for a Punto HGT, free to any FiatForum member if they want it.
Cheers,
Mick
How I did it:
5) Problem solved.
4) Problem solved.
Cheers,
Mick
