@the green vanper. I promised above that I'd report back after I'd had a play with the jump pack. Well, Mrs J got a bit tied up in knots trying to get the sim card ordered so I spent some time with her and between the two of us we seem to have managed. We've bought one that renews every month and I've linked payment to my paypal account so I don't have to give them my credit card number. I've no idea if that's a good way to do it but it's worked and the card should be here within 2 days they say. Mind you, we've no idea what you do with it once it comes but "high tech" son in law says he'll sort us out.
So, that task accomplished I hauled out the old Punto battery and checked it over. This battery was not holding voltage very well when in the car but I keep it on the smart charger a couple of times a week and it's good enough as a standby power source when needed for continuity if a vehicle battery needs to be disconnected for some reason. I checked it with my voltmeter and it was showing about 11.4 volts. I connected up both the jump pack leads - pos lead to pos terminal and neg to neg, as detailed in the instruction leaflet. I was expecting the pack to "come alive" as the leaflet says to just connect the leads and charging will start. But, nope, nothing happens. The little display screen stayed blank. Hmm? Oh well, maybe it needs to be switched on? There is only one button, the green one. So I pressed it and immediately there's a substantial "Click" from the unit, the red indicator illuminates and the wee display panel lights up to show battery voltage at 11.5 volts and under it the unit charge slowly increasing with the %age showing to it's right. Over the next two or three minutes the unit charge steadily increased until it showed 15 volts and 100%. The red indicator goes out and the green one illuminates. So fully charged and ready to go. Battery voltage now showing around 10 volts. So seems to have charged successfully. Unfortunately at this point my neighbour stuck his head round the garage door and asked what I was up to which completely distracted me. Anyway, he's a nice chap so I showed him the jump pack and explained about it. Turns out he is some sort of industrial electronics engineer and understood everything I was talking about. In particular he knew all about super (Ultra as he called them) capacitors and was very interested in this application of them.
So, having "shot the breeze" for a while I connected my voltmeter to the jump lead clamps, which registered the existing battery voltage of course, (which had recovered by a couple of points of voltage in value, but only to about 10.5 volts, while standing) and pressed the green button again. I got exactly what I was expecting. There was a click and the voltage on the meter jumped to just under 15 volts and then fell back linearly to about 13 volts before the jump pack turned itself off with a click and immediately started recharging. I let it recharge before disconnecting the leads because this is what the leaflet says to do. At the end of all this the vehicle battery was showing about a volt less than it had been showing when I started.
So, apart from the unit not commencing to charge immediately on connecting the leads but needing you to press the green button, it's done everything I expected it to do, including charging to 15 volts and then pushing a goodly whack back into the battery when the "start" function was activated. It held in the region of 14 volts for a good ten to 15 seconds before falling away slightly and then breaking the connection. I think it gives you around 20 seconds cranking time before turning off (probably to protect itself?) I'm in no doubt this unit will do what it needs to do in a jump start situation. Of course the proof of the pudding will need a real life jump start situation but I really can't see any reason why it shouldn't work very well. I was also impressed by the "meaty" click of the solenoid/solenoids (don't know if there's more than one) which you hear when it's starting to charge and again when, once charged up, you change from parallel to series connection of the capacitors. They give the impression of being well up to the job. By the way, if you do nothing with it then it shuts down after 30 seconds. Regarding the commencement of charge requiring the button to be depressed - whereas the leaflet seemed to say it automatically commences when the leads were connected to the battery, I think there may be an inbuilt delay (which I overrid by pushing the button?) Next time I try it I'm going to connect the leads and wait a wee while to see if there's a delay. If it were to start pulling current immediately that might risk a spark being generated as you connect the clamps? so either a delay, or pressing the button, to complete the circuit makes sense to me.
So now it's in the boot of the car, fully charged, waiting for action. I'm going to monitor the stored voltage to see at what rate the capacitors discharge. One review I read reckoned it would hold enough voltage to start a small/medium sized engine for several days.
I've really enjoyed myself and my neighbour's input from someone who understands electronics was very interesting. I actually carried the battery to just outside the garage door in case something went badly wrong - high currents involved - The sun was shining, it was really quite nice and warm and the companionship and "banter" with my neighbour made for a very pleasant three quarters of an hour.
